Creo view express 6.1 markup tab
what is the purpose of the mark up tab in Creo viewer. If you can't save the mark up that were created in the 3D model in the viewer? I've added leader notes to the model, and I want to send it to a co-worker. So he can see my notes. He can only see the model but not my notes. He also would need to rotate the model for other notes. in back. Is it even possible?
Thank You
Juan
Hi, I also have the same problem.
Searching the internet it seems that Creo View Express is limited to opening only and does not allow saving.
https://community.ptc.com/t5/Addtl-Creo-Products-View-Sketch/Saving-in-Creo-View-Express-and-Creo-View-Lite/td-p/908946
The only thing that is therefore possible to do is save print screens or send the view via email via the command
File >>> Send >>> Active view by email.
I realize that these alternatives are disappointing but I can't tell you anything else for now.
I have a question for you: have you by any chance already evaluated another mode or viewer program to get around the problem?
P.S. I'm using Creo View Express 10.1
