Creo View Express not showing native Creo 2D assembly drawing views.
Hello, When I open a native Creo 2D assembly drawing with a number of pages, not all the views/images per page show? I am left with only text, tables and the product views are missing.
Is it because the assembly is to complex?
I am using Creo View 10 & Creo parametric 9.0.4.0
Thanks in advance.
It might be due to the fact that you assembly parts have interference with other parts. We notice that lines were missing in drawing views and that was the culprit.
JN-034-ParticipantAuthor
Thanks for your reply.
I just opened a smaller assembly drawing with a known interference and the majority of the view were there but as you mentioned some lines are missing where the interference occurs.
I assume with a large complex assembly Creo Viewer just gives up totally and shows no view all together.
That is going to be somewhat frustrating!
That means Creo Viewer will not be usable for most of my drawings.
Does anyone know of any work arounds apart from designing parts that do not interfere?
