Creo View Lite, change lighting settings
Before I spend much time looking for it (unsuccessfully, because it doesn't seem to be there):
In Creo View Lite there is no way to change the lighting settings (e.g. spotlights), right?
This must be done (at minimum) in Creo View MCAD, and saved from there as an annotation set, correct?
Hi vecTor,
Refer to the Feature Comparison document referenced in PTC article CS37677, this confirms that Edit Lighting is only available in Creo View MCAD.
Gary
Hi vecTor,
Gary
