3-Newcomer
Edit structure option in Creo illustrate is not highlighted,
I'm trying to move the Ebom of one of the component, since the option is not highlighted it is taking me a lot of time to moving it manually. It usually never happen.
Kindly help me to identify a what was the problem
I'm using version 11, have full professional license
Catalina
Community Manager
Hi @SD_10814524
Thank you for your question.
Best regards,
Catalina | PTC Community Manager
agarland
If you see 'Illustrate Professional' as the edition under File>Help>About Creo Illustrate as shown in the attached image.
Then I would suggest contacting tech support and raising a case.
