Enable to create hotspots in Creo Illustrate
At present a customers uses IsoDraw CADProcess for creating cgm files with hotspots.
Customers would like to switch from IsoDraw to Creo Illustrate, but hotspotting functionality is missing in Creo Illustrate.
Thank you and best regards,
Jozef.
8-Gravel
Hello Jozef
I know its been a while since you posted this issue but the current versions of Illustrate seem to support this function.
Are you still working with Illustrate and has the new hotspot function been helpful to you?
Kind regards,
Anja
