Functions to order Callouts in Creo Illustrate base on data from parts
We think it would be usefull to have som possibility to order callouts based on part information. For example if the parts item_tags are alphabetical names you may want the callouts to follow the same order. So if one parts item_tag starts with A and the next one starts with the letter B the callout for A should be 1 and the callout for B should be 2. The renumber and order functionallity of callouts in illustrate are very limited at the moment.
At least you could vote yourself for your idea 😉
