How can I switch between the two working windows (project 3cdi)?
Hello!
If I open in Creo Illustrate two different files "3CDI", then how can I switch between their open windows (shortcut "Tab", "Alt+Tab" does not work)?
You're not really opening two files at once. When you do File -> Open, currently opened illustration gets closed.
You can run multiple Creo Illustrate instances and open different files in each instance.
VladimirN24-Ruby IVAuthor
Dmitry Tsarev wrote:
...You can run multiple Creo Illustrate instances and open different files in each instance...
In this case it is necessary to have in a license file more license keys ("Qty" = Quantity) for Creo Illustrate .
This is the only way (I'm aware of) to achieve the functionality you're looking for
