How to change Spin Center for wrench object in Creo illustrate
Hello all,
I'm trying to create some sequence in creo illustrate, I have added wrench from object. When I rotate wrench it rotate at center, I want to rotate wrench with tip of wrench is fixed to bolt. PFB PNG for reference.
agarland
agarlandAnswer
To change the the csys you need to:
  1. Select the part
  2. Right click and select "Location>Select csys"
  3. You can now define the new csys
For the wrench I would first select the cylindrical face (which then shows the axis)
Then select the axis you want to rotate around.
Rotate around new csys.pngHope this helps.
agarland
agarland16-PearlAnswer
  1. Select the part
Velkumar19-TanzaniteAuthor
Thank you @agarland . It works.
