How to disable the option Monochrome display from active view in Creo view
Dear Experts,
Can we disable/lock the option Monochrome display from active view in creo view ?
Is it possible to lock/ disable these settings using server_prefs.xml file ?
If yes, kindly guide
Athmanand
Athmanand,
send your question to PTC Support.
Martin Hanak
Athmanand,
Yes it is possible. This needs to be added to the admin_prefs.xml file and pushed out to the users.
Anand1-VisitorAuthor
Can you share what are the settings that are to be done in admin_prefs.xml file ?
Athmanand
