Illustrate video output - can't get the size right
Facing the same issue with Creo Illustrate 11.0
Not able to predict the output in video.
Please help asap.
Thanks in advance.
Aditya Gupta
Catalina
Community Manager
Hi @Aditya1702,
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina | PTC Community Manager
Hi @Catalina ,
Good Morning,
I have created an animation in creo illustrate with some callouts & notes, but as I am exporting the animation as a nmp4 file the notes, callouts & even the 3D model is misplaced from its position as in preview.
for eg. If I have kept the 3D model in the center & inset view in top right & note in bottom left, so after exporting the animation in a video file the positions of the 3D Model, inset & notes shouldn't change but its being misplaced by some distance.
Thanks & Best Regards,
Aditya Gupta.
Ramon_Bohne
Hi Aditya1702,
it looks like you need to assign a page size. Then Creo Illustrate knows which region to capture.
Best Regards
Ramon
(Siemens Energy)
