Insets
Is there any way to either point an inset to a different figure within a PVZ or have the inset display a different sBOM than the view it's drawn from?
Can you import two sets of the same model to create more flexibility? You could certainly show one in phantom while animating / exploding / hiding parts in front of it.
Is there a way to animate an inset without animating the model?
Is there any way to create a viewport from one figure to the next instead of using this seemingly limited inset tool? For example; I create a locator with several annotations for a transmission like "go to pump installation" and by clicking the notation, I can open the pump installation figure? or potentially the pump installation PVZ?
