Is there any way to influence default backup behavior in Creo 2 Illustrate?
Our users are working with full system data and the time between backups keeps interrupting them and they would like to turn it down. I can see an option in Creo 3 but i can't see an equivalent options box in Creo 2. Is there a backdoor way i can make them happier with?
Chris,
You are right that UI has been added in Creo Illustrate 3.0 to control this. For Illustrate 2.0 the following will help
http://communities.ptc.com/thread/39416?tstart=30
