Item tag change
is it possible to change the "Item tag" in item list under Creo Illustrate?
What I mean by that:
In my case Item Tag displays part numbers because it references one of 3 parameters(attributes) from Creo (don't know which yet"). Either "PTC_WM_NUMBER", "sBOM" name" or "eBOM Name". Probably the sBOM name.
Nevermind...somehow I missed the column chooser...
