More Creo 2 Item List Questions!
1. In the Item List menu in Manual mode, if I select a .PRT item (a part) and then click "Annotations" and select the circled number with a line, I get exactly what I expect. But if I select a .ASM item (an assembly)....... I get nothing at all! Is there a way to do this?
If I select Automatic mode, it automatically annotates EVERYTHING in the view - in this case, hundreds of items - in which case I have to go through and "delete" many items, one by one, and renumber all of them laboriously. Not satisfactory!\
2. Some of the .PRT items are used in different functional assemblies. If I select several instances of the same .PRT, the Item List uses the same annotation number and increments the Qty number. This prevents me from renaming each of the .PRTs with their specific functional usage. Again, any way around this?
Thanks in advance!
Tom Burton
