Need more appearance adjustment options in Creo Illustrate
Creo Illustrate has a very limited appearance adjustment. I would like to be able to adjust the “highlight “or “shininess” in the appearance color to make an object look more matte, to look more true to life. The colors give a shiny appearance.
Please add more adjustments for the appearance other than transparency and RGB values.
Creo Parametric has great appearance property adjustment options.
StephenW
I'm not entirely sure why it's not an option to change a specific one to solid but in the drawing setup file, you can change the option ARROW_STYLE to FILLED and all your arrows will be filled.
Thank you for the reply.  I am aware of this but we really have a need for open and closed arrowhead at the same time.  Seems like this would possibly be one of the most simple enhancements they could ever implement.  But will they ever do it?
StephenW
For clarity, you may want to add that to your idea and I don't disagree at all. Why can I have an open and a filled square and not an open and filled arrowhead?
