Opening a c3di creates all annotations to show up
- 1 reply
- 1442 views
- Translate All
We are working from a Parts List in Windchill, which creates a c3di file. When we Update Illustration and open the c3di file in Illustrate, every part that has an Item Number will have an annotation applied to it. So if I have 50 parts in the model, all of the parts will have an annotation when it is first opened. Also, when I make a new Figure, it does the same thing. It does this every time you open the c3di file whether it was saved like that or not.
Is there a command that tells Illustrate to automatically populate every Item Number by default in some config file somewhere? I tried looking but I couldn't find anything.
Windchill 11.1
Illustrate 6.0
Mike
