Output Creo Illustrate Sequence
I have created a repair procedure consisting of about 12 sequence steps in Creo Illustrate 3.0. I am able to step through the sequence in Creo Illustrate.
BUT...
How do I export or output this procedure so it can be seen and followed by others?
Any help appreciated!
Tom Burton
The output from Creo Illustrate is to Publish to PVZ.  The end user consumes the output in Creo View.  It's also worth noting that the PVZ and sequences you create can be consumed in ThingWorx Studio for Augmented Reality.
