PTC Creo View
I was just wondering why am I not able of modifying the cache size to another value different than 2 GB?
Option appears to be unavailable for edition. Why is that? If I recall correctly, this was not the case before.
Ian_CureAnswer
With help from a colleague in the states…
Edit “user_prefs.xml” which can be found (in my case) C:\Users\user\AppData\Roaming\ptc\ProductView
Search for “cache_size” and change the “value” to your requirements.
Save and start CreoView
Ian_Cure13-AquamarineAnswer
atorres1-VisitorAuthor
Hey man,
thanks for the note on that.
I've done it and it worked! I appreciate it!
Dale_Rosema
Alejandro Torres‌
Don't forget to mark the answer as correct.
