Rearranging/inserting figures in Creo Illustrate
I am new to Creo Illustrate and I have a question regarding rearrangement/insertion of of figues in Creo Illustrate 3.
When I insert a new blank figure it's always added at the end after all the existing figures. If I want to add this in between let's say figure 1 and 2, how do I do that? I don't seem to be able to just drag and drop it there. And the same if I for some reason want to rearrange the sequence of the figures, how can I do that?
Another example : If I delete Figure 2 and later want to add a new "Figure 2" then how can that be done without it ending at the end after all the existing figures?
2-Explorer
August 8, 2014
I believe article CS57709 is still valid with Creo Illustrate 3.0 and this is not part of the functionality:
http://support.ptc.com/appserver/cs/view/solution.jsp?n=CS57709
Okay thanks Gunter.
That's really a shame. I hope this function will be implemented in the future 😉
Oddly enough in sequences you can rearange steps easy but figures you cant. PTC tend to do something in one part of software and in other lack same capability.
