11-Garnet
Remove Dimensions from drawing for WVS Publishing with RCP recipe file
Any hints how to achieve a Drawing without Dimensions, Surface symbols and GD&T symbols while publishing?
I obviously have been wrong upon thinking that unchecking the options in the recipe editor takes care that no Dimnsions appear on the viewable of a Creo .drw Drawing.
So my recipe file contains all the following lines but all dimensions and other stuff I don't want to see (surface, GD&T etc.) is still in the viewable.
adapter/convPlanarGTol=0
adapter/convPlanarSurfFin=0
adapter/convPlanarNote=0
adapter/convPlanarRefDim=0
adapter/convPlanarDrvnDim=0
adapter/convPlanarSymbol=0
adapter/convPlanarSDTag=0
adapter/convFloatGTol=0
adapter/convFloatSurfFin=0
adapter/convFloatNote=0
adapter/convFloatRefDim=0
adapter/convFloatDrvnDim=0
adapter/convScreenNote=0
adapter/convScreenSurfFin=0
adapter/convScreenSymbol=0
TIA
ULi
Good Question...most of these preferences for recipe are associated to model(.prt/.asm) publishing for MBD usage.  Excluding  or filtering out specific 2d content that the publisher workers will load on the publisher for drawings may need a different type of management.  Maybe there are config settings that may drive how the drawing loads on the workers.
