Revised objects: Creo Illustrate/Process Plan
We're in the implementation of Creo Illustrate 9.1 to be use for representations in MPMLink Process Plan.
We're getting bugs sometimes with c3di files not updating. Probably a basic question here, but looking for what is the right way to manage.
Q1- When Revising a Process Plan and Illustration files, Does the source file needs to be included?
Q2- I can't collect (not even have the option) to collect the source files when files are released and need to be added for a Change.
Q3 - The revise option does not work when reising all objects at once. is this normal?
Hope someone has some insight/solutions here.
Thanks in advance!
Emeritus
Hi @AR_10458781,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It also helps to have screenshots to better understand what you are trying to do.
Vivek N
Community Moderation Team.
vdegaonkar
Take a look on Article - CS420191 - Post publish on Illustration does not occurs when Illustration is revised without associated Operation in Windchill MPMLink
if this represents your problem then may want to plan update to supported CPS>
Else, do consider posting this issue on Windchill Community page instead of CreoView/Illustrate.
Thank you for you answer!
It does sound related to what we're having. I'll validate with our IT team to check the CPS.
Otherwise, I'll post it where you have suggested.
Thanks!
