Save As Illustration Problems with SVG
Hi
To me it seems as it's only possible to export a figure to SVG using Shaded with Edges or HLR render mode. When I use e.g. the White Shaded Illustration render mode it looks as if the SVG still uses the Shaded with Edges render mode. Is this correct?
