Transform Dragger...
A very quick question: How can you move the Transform Dragger so that it appears in a zoomed view of a large assembly? Quite often, I need to transform the location of a large object, but need to look at a detailed zoomed view while moving the object, but the Dragger could be located at some distance from the required view. I know I have seen the answer to this before but can't find it!
Thanks in anticipation,
Brian
agarland
You can change the transform dragger location using the RMB option 'Location' and then 'Select csys' but this does change the coordinate system to the selected part.
I think what you are asking for is that the transform dragger stays 'in view' when zoomed in on a large assembly.
This is an enhancement that will be available in the next release of Creo Illustrate (4.0) which is due out later this year.
bwhelan1-VisitorAuthor
Thanks Adrian. Much appreciated. Roll on Creo Illustrate 4.0!!
Brian
