Trying to start rcpedit.exe but just get an error
Hi all
Just having my first look at the recipe files for exporting to Creo View Express but I cannot start the rcpedit.exe tool.
I get the DOS prompt error as attached.
I am running Creo 2.0 m150 on a Windows 7 64-bit laptop.
Anybody have any suggestions?
I have tried copying and running the rcpedit.exe from the location listed in the error but to no avail.
Neal
Neal,
it looks like that it is a bug Creo 2.0 M150 64-bit installation (and also Creo 2.0 M160, Creo 3.0 M030).
In Creo 2.0 M050 64-bit installation rcpedit.exe works, because the following directories/files exists.
You can try to install Creo 2.0 M150 32+64-bit and hope that this kind of installation will solve the problem. You can try to copy missing directories/files from M050 into M150. Also you can open Case at PTC Support and ask PTC to correct the problem.
Martin Hanak
Neal,
Martin Hanak
nhanratty1-VisitorAuthor
Hi Martin
Thanks for the reply...I checked my install and yes that folder and those files are missing. I also checked an m120 installation and they are missing on it also.
Separate to this I downloaded the specific msi for the recipe editor from the PTC Software Updates page and then copied the i486_nt folder into the location as shown in your image. That fixed the problem.
Thanks for your help.
Neal
