Unable to find libpvgltfwriter_vs16.dll
I hope I'm in the right place.
I use pvsoptimize.exe (included in PTC CREO viewer) and I have a problem.
In logs, it's indicated that "C:\Program Files\PTC\Creo 7.0.0.0\View\x86e_win64\obj\libpvgltfwriter_vs16.dl" not found.
Could you say me if this .DLL is from PTC Creo view or not ? Do you have it on your computer ?
Many thanks in advance
In "Creo View Express" this dll file can be found in the following path: C:\Program Files\PTC\Creo\View Express\i486_nt\obj
Thank you for your answer but I don't find the dll in "C:\Program Files\PTC\Creo 8.0.0.0\View Express\i486_nt\obj".
There is libpvg_vs16.dll.
Do you have the version 8.0.0.0 or a previous version ?
Thanks in advance
Yes, I have an earlier version (for 32-bit). I will test the latest 8.0 and write later.
vdegaonkar
Hi:
Creo View does not package this specific DLL.
Can you please elaborate your usage with PVSOptimize and which recipe file are you using?
thank you,
-Varad
