Use Preset Explode if source data is definied in the subassemlies and not only in the top-level
Expect to obtain the Creo Elements / Direct Modeling configurations of the subassemblies in the Preset Explode  of Creo View
Description:
In the help you can read that "You can use the Preset Explode function only if the source data has top-level explode states defined".
This is the structure on Creo Elements / Direct Modeling.
The objects are stored in Windchill.
The visualization of Sub-Assy1 is a monlith visualization  and the visualization of the Top-Level-Assembly /Tops-Assy is a strutcure visualization.
Only the Modeling configruation  off the Top-Level-Assembly is available in Creo View in the
Preset Explode
 We also expect to obtain the modeling configurations of the subassemblies in the Preset Explode  of Creo View
You can only obtain that type of functionality if you are using Creo View Positioning Assemblies. Otherwise it just does top level assembly explodes.
