Dale_Rosema
Jun 18, 2024 3:48 PM UTC
Asking to select "Location"
I started a new post in the PTC Community Feedback, but when I went to submit, it asked me to select a location. I expanded the PTC Community Information Center and there was able to pick PTC Community Feedback. Not sure why since I started there in the first place.
AndrewK
Community Manager
Jun 18, 2024 4:33 PM UTC
Hi Dale,
If you are on a board and click the "Start a topic" button, that board should already be selected. In fact, you shouldn't even see a "Select Location" option. You should only be required to select a location if you are somewhere else on the community and use the "Start a topic" button in the header. You may have been one level up on the category page.
Dale_Rosema
Jun 18, 2024 4:34 PM UTC
Are there any time barriers since the last login that would do this also?
AndrewK
Community Manager
Jun 18, 2024 4:41 PM UTC
No I don't think so. It could be you were on a different page while still seemingly being on the Feedback board. For example, if you were on the feedback board and did a search on that board and then posted from the search page it would not realize where you came from and force you to choose a board.
