Dale_Rosema
Jan 27, 2025 2:47 PM UTC
Filter Heading - Unread
Would it be possible to add another header/filter underneath the group sub-heading? Sometimes posts are moved from one category to another and may get buried in the transition if they are 5+ days old.
AndrewK
Community Manager
Jan 27, 2025 2:57 PM UTC
Hi Dale,
Unfortunately, that's not possible with the API available to us for customizations. However, there is an unread topics page you can reach from each board.
Dale_Rosema
Feb 12, 2025 12:40 PM UTC
Is that a moderator setting? I am not seeing it?
AndrewK
Community Manager
Feb 13, 2025 2:10 PM UTC
I need to test it out to be sure, but I suspect it is the difference between posts and topics. The component shows unread topics meaning an entire conversation. If you have seen a topic, it won’t appear on the unread topics list. However, if there is a new reply to that topic that you haven’t seen, it will show up in the count of new posts. I will test this out to confirm how it works and let you know.
