tbraxton
Apr 29, 2021 7:21 PM UTC
How to request the addition of a label
What is the process to request the addition of a label to classify posts?
As an example mapkeys ; in the 3D Part & Assembly Design forum there are 600+ posts about mapkeys. It would be nice to have this label available for use when creating posts. It is also a bit confusing as to where mapkey discussions should be posted, Customization or 3D Part & Assembly Design. Clarification on where to post common labels may be helpful.
I suspect the intent is that Customization was created for the APIs (Toolkit, Jlink, etc.) and was not intended for discussions regarding customization in Creo Parametric that is controlled by the customization.ui file.
