23-Emerald V
Dec 7, 2017 8:43 PM UTC
The contents of the attachment doesn't match its file type.
Just to re-iterate, because it is getting VERY annoying.
Can you (PTC/Lithium) please solve this bug where the forum will not accept valid Mathcad and/or Prime files as attachments.
For further information, see here: https://community.ptc.com/t5/PTC-Mathcad-Questions/Survey-direct-Mathcad-files-attachments/m-p/476730#M172277.
    LucMeekesAnswer
    23-Emerald V
    May 17, 2018 10:36 AM UTC
    Apparently it did get (at least some of) the attention it deserved. The problem is gone for now.
    StephenW
    Dec 7, 2017 9:28 PM UTC
    I was just curious so I went and found mathcad files (in the mathcad forum)
    **edit**it worked on the one mathcad11.mcd but the 2 prime files refused to attach.
    I certainly understand the frustration!!
    LucMeekes23-Emerald VAuthor
    23-Emerald V
    Dec 7, 2017 9:46 PM UTC
    Apparently you never had true Mathcad installed on the machine that you're using...
    StephenW
    Dec 7, 2017 9:51 PM UTC
    Correct
    Emeritus
    Dec 7, 2017 10:48 PM UTC
    Hi LucMeekes,
    Thank you for alerting us to this issue. We are investigating the issue based on what you have reported here and in the linked post. We will provide an update as soon as one if available.
    Thank you,
    PTCModerator
    23-Emerald V
    Jan 8, 2018 5:36 PM UTC
    I don't see the reason for a 'Creo sneak preview' anouncement on the forum part for Mathcad. I think I have better use for it, especially since this bug is still not fixed.
    Please change that text to something like the following:
    "If you experience problems when attaching a Mathcad sheet file ( .mcd, .xmcd or .mcdx) to the message then zip it first.
    To get the .zip file, use Windows Explorer, select the sheet file, right-mouse click and select "Send to" then "Compressed (zipped) folder".
    This results in a .zip file containing the worksheet that you can attach."
    Jaime_Lee
    Community Manager
    Apr 6, 2018 6:11 PM UTC
    DONE! 🙂  I apologize for the delay.
