Jan 8, 2018 12:38 AM UTC
using ptc community portal
We are 2 members of this portal.
Using same computer.
Impossible to change username...
Signin : last user.
sign out.... signin...
No question, only the same.
Is it normal ?
Is there any solution ?
GB
Jan 8, 2018 1:07 PM UTC
you have to:
and then login as different user.
2-Explorer
Jan 8, 2018 7:03 AM UTC
I have also faced this. Log out and try closing entire browser. With this way, it works but not always!
you have to:
TomU
Jan 8, 2018 1:24 PM UTC
Like Martin said, the trick is to sign out of support.ptc.com.  If you don't sign out of there then the community will automatically keep signing you back in as the same user.
Jan 13, 2018 11:50 AM UTC
One other way around this really annoying bug (guess PTC will call it a feature) is to clear the the browser chronics (especially cookies or active logins) after you log out from the forum.
I really would prefer my login data here in the forum being different from that at PTC support! They serve different purposes anyway.
