(-9) Invalid Host
Hello can somebody help me with this problem I have to finish my project but i cant due to this Warning. It is a "License Warning" and it says: "Requesting CREOPMA_SchoolSTD6... -(9) Invalid host. Run ptcstatus.bat for server status".
I get this warning everytime when I open Creo please help!!!
this message tells you that Creo cannot find network card mentioned in license file.
1.]
License file is located in hidden C:\ProgramData\PTC\Licensing directory.
You can open license file in Notepad and locate PTC_HOSTID= text. Equal sign is followed by MAC address of network card.
2.]
You can open Command prompt window and launch ipconfig /all command in it. Command output contains list of all network cards installed in your computer.
3.]
MAC address mentioned in license file must exist in ipconfig /all command output.
Thank you so much for your reply. The MAC address does exist in ipconfig/all.  Does different Networks have different MAC addresses, because this warning occurs everytime when I am using Creo not at home. I sometimes have to work on my project at school or at a coffee shop so do I have to change the MAC address from the located Network in PTC_HOSTID= ?
Again thanks for your reply and help
1.]
Each network card is assigned a unique MAC address.
2.]
Usually notebook has two network cards - Ethernet (LAN cable) and WiFi
3.]
In Windows, MAC address of WiFi can be randomized - this means Windows generates random WiFi MAC address and use it instead of WiFi physical address.
To continue discussion I need to get:
a.]
PTC_HOSTID=xx-xx-xx-xx-xx-xx from your license file
b.]
output of ipconfig /all command
Open Command prompt window and launch ipconfig /all > ip.txt command. This command creates ip.txt file. Please upload it.
