A1 Format
  • November 15, 2012
  • 1099 views
I need to create an A1 format. Is there any tutorial or step by step guide for this?
Is it possible to import an A1 autoCAD border into the format?
Any help is appreciated
    Diarmaid, I checked with some experts and here's the response.
    When you create a new format (File > New > Format), there is a “Standard Size” drop down menu where you can pick A1.
    Yes you can import the format from AutoCAD. Create an empty A1 format per above instructions, then use the “Import Drawing/Data button on the ribbon to import the AutoCAD format. You may have to export DXF from AutoCAD.
    Hope this information helps!
