absheik_is_dak9.asm.1
Hello, I followed the steps that you told me to make sure all parts are on the file. Would you be able to take a look and tell me where the problem is so that I can make a working servo motor and simulate its movement in motor analysis.
    Abhishek Vijayakumar‌, the attached ZIP only contains the .ASM file. It does not contain all the .PRT files required for the assembly. Please take a look at How to Save a ZIP Archive of your Creo Parametric Assembly? to make sure you are creating a copy of the full assembly when creating the ZIP.
