Academic Simulator - Can't load a configuration
After saving the configuration made in Academic Simulator in a json, using the option to save the configuration made previously, I tried to recover this configuration, but Academic Simulator does not finish the process, it remains in the "Loading things ..." screen for forever.
Is there any known bug with the Academic simulation around the configuration saved in json format?
Olatz
Hi there! Could you please send me the json file you are using?
