May 10, 2012 8:17 AM UTC
Accessing Configuration Editor in Creo Direct
I am unable to access the configuration editor in Creo direct Educational using the usual File > Options > Configuration Editor pathway.
The configuration editor text appears greyed out and is inactive as a link
The Creo 1.0 Educational version is M020 and I am running it on Windows 7 Professional OS
Access to the Configuration Editor in Creo Parametric is fine - so I'm a bit puzzled....?
Any advice appreciated
    May 10, 2012 7:21 PM UTC
    Hi John,
    The configuration editor is not available in Creo Direct. All the options you need should be available in the Options dialog anyway. Is there a specific option that you need that is not available?
    Martin
    18-Opal
    May 14, 2012 1:03 PM UTC
    Hi John,
    You will need to run the session as administrator. Since you are running Windows 7, if you want to edit the config's for Creo Parametric, you will need to write to the c Drive. Without starting the session by right mouse button on the icon and selecting Run As Administrator, you will not be able to write to the C Drive. Once started with Admin rights, you will be able to edit the options or add new ones.
    mark
