Mar 26, 2013 10:31 PM UTC
Assembly Deactivate
In a n assembly, I want to edit a part with all the rest visible. So I click 'Activate' and make my changes. I cannot find a way to 'deactivate' and go back to normal assembly mode, though. The only way I have found is to save everything, close creo completely, and reopen. How do I Deactivate?
    Mar 26, 2013 10:48 PM UTC
    Right click on the top level in the tree and select Activate again.
    Sep 9, 2022 11:04 AM UTC
    Is there a way to automate this action with a Mapkey?
    I use quite often the "activate" in assembly, because I need to copy some parameters from Creo to SAP
    Then I would like to be "back" the the main assembly with a keyboard command, instead of right click+deactivate
    Thanks for help in advance
    Sep 9, 2022 4:04 PM UTC
    to activate main assembly simply press CTRL+A.
    Jan 10, 2023 10:57 PM UTC
    i figured that out AFTER 40 min struggling finding a command called DEACTIVATE; which is what common sense would do... why CREO uses select the top assy and ACTIVATE it, is beyond my understanding
    Jul 14, 2026 8:23 PM UTC
    This is actually really stupid when you have a heavy assembly because clicking the top level causes the ENTIRE ASSEMBLY to be highlighted in the graphics window. Every part and fastener while your machine chokes.
    One workaround (inexplicably) is to move to a different part or assembly window and back again. And don’t get me started on moving between part windows.
