Can't change language in Creo Parametric 7.0
Hi, i can't seem to change the language in Creo Parametric 7.0 from english to german.
I've already tried adding the "ENV=PRO_LANG=german" line in the parametric.psf even with german language selected during installation.
I've also changed the system language with a clean install but without any results.
check whether your Creo installation contains directories named german, for example C:\Program Files\PTC\Creo 7.0.2.0\Common Files\text\german.
Hey,
I've checked and my directory contains german folders.
Hey,
please upload parametric.psf file located in your installation. I will check its contents.
Note: Put the file into zip-file and upload zip-file.
