Can't install purchased Mathcad 8 student edition.
Trying to install Mathcad 8.0. I downloaded pim_installmgr_mathcad_8.exe. I am using Window 11. When I runt pim_installmgr_mathcad_8.exe a dialog asks permission to make changes to my device. I respond OK and then nothing happens. No install.
1. Did you use this download link? "Mathcad Downloads": https://support.ptc.com/support/mathcad_downloads.htm
2. Please show a screenshot of your error.
download MED-60893-CD-280_8-0-0-0.zip from https://support.ptc.com/appserver/auth/it/esd/academicFree.jsp page, unzip it into new empty directory and run setup.exe.
Thank you. I downloaded and tried with the same exact results. I cannot show a screenshot of the error as the setup program just stops. No error is shown. no instal is done.
1.]
According to https://www.ptc.com/support/-/media/support/refdocs/Mathcad_Prime/8,-d-,0/Mathcad_Prime_8_0_Platform_Support.pdf?sc_lang=en Windows 11 64-bit 21H2 is supported
2.]
Please provide detailed information about hardware configuration of your PC. You can run System Information application, Save .nfo file, zip it and upload .zip file.
3.]
Please provide complete absolute path to setup.exe you are trying to run.
Also you can run Event Viewer and search for an error message related to setup.exe.
