Apr 13, 2012 8:57 AM UTC
Can't make helical sweeps within hollow cylinder? - Creo Parametric (School Edition))
Hi!
I've been trying to make a helical sweep within a hollow cylinder, but for some reason the helical sweep doesn't interact with the hollow cylinder (as in it doesn't become embedded on the inside of the hollow cylinder)
the part attached should make my point clearer.
any help is greatly appreciated
PROBLEM 2:
Right now, the helical sweep can't interact with a solid cylinder either - am I using the right tool??
    Patriot_1776
    Apr 13, 2012 1:46 PM UTC
    If you have a school edition, none of us normal license users can open your files, sorry.
    Hao1-VisitorAuthor
    Apr 14, 2012 12:05 AM UTC
    don't worry I solved it
