Cannot generate node-locked license - "Access Denied / Insufficient Privileges" (Creo 13 University Edition)
Hello PTC Education Team,
I am a student at Nanjing Normal University, China. I registered a PTC academic account and successfully installed Creo Parametric 13.4.0.0 (University Free Edition), but I cannot activate it because no node-locked license can be generated.
Account: registered with my university email - I can provide it privately if needed.
Host ID: C4-EF-BB-E9-25-F8
Creo version: 13.4.0.0
OS: Windows 11 (64-bit)
What happens:
1. In the Creo Installation Assistant, "Node Locked License Generation" with product code BK130908EDUNIVERSITYED returns an error. I also tried BK130908EDSTUDENTEDUNI with the same result.
2. Opening https://my.ptc.com/licensing/dashboard shows: "Access Denied - Insufficient Privileges. Your web account does not hold the following required privileges to access the application: License Management Reporting for read-only access; License Management Licensing for configuration and license file generation access."
3. Launching Creo shows: "License not found - Creo appears to have been installed using the 'Skip License' option. Run the reconfigure utility to use your enabled license."
Could you please:
- enable License Management privileges on my academic account, or
- send me the node-locked license file (.dat) for my Host ID, or
- confirm the correct product code for Creo 13 University Edition.
I can provide screenshots of both errors if needed.
Thank you very much for your help.
Best regards,
Shiyu Zhang
