Cannot install Creo for K12 on my PC
Hello. I have downloaded Creo for K12 and unzipped the archive. I have disabled antivirus and firewall and clicked to run "setup.exe" as administrator - but then nothing happens. I have windows 10. Thank you
    try launching setup.exe on different PC (ask a friend).
    but i need it to work on my computer, so this solution does not help
    There are a few reasons for that issue to happen:
    1. Corrupted file (download issue) - you can check is the setup.exe works on another computer, if it doesn't the file may be corrupted so re-downloading it may resolve the issue.
    2. Windows is not on 64 bits - except Creo 3.0, all new Creo editions work ONLY on 64 Bit windows.
    3. Antivirus or antimalware is blocking the executable file - disable them during installation.
    4. Windows has corrupted registry files that make the exe file not work. In this case the only solution is to repair or reinstall Windows.
    Alex
