Cero 2.0 closes without error or warning
Some times it will crash on my first extrude or round, some times I can work for about 5 minutes before it crashes. Any Ideas?
Here are my computer specs if that helps:
CPU Intel Core i3-4370 3.8GHz Dual-Core Processor
Motherboard Gigabyte GA-Z97-HD3 ATX LGA1150 Motherboard
Memory G.Skill Ripjaws X Series 16GB (4 x 4GB) DDR3-1600 Memory
StorageSamsung 850 EVO-Series 120GB 2.5" Solid State Drive
Video Card AMD FirePro W4100 2GB Video Card
Operating System Microsoft Windows 7 Home Premium SP1
Monitor Dell P2213 60Hz 22.0" Monitor
    8-Gravel
    August 3, 2015
    Try Screen Resolution settings 1280x1024 for your system. Its PTC recommended.
    Also make sure that inbuilt graphics drivers are not installed if you want to use AMD Graphics. Both together can make crashes as per my experience.
    Jignesh
