Aug 3, 2024 6:16 AM UTC
Changing size of arrows in drafting sheet
HI team,
I've been working on a drafting with multiple pages sheets. Here i need to change the size of the dimension;s arrow size in different sheets. In Detail properties, whole document's arros only changed, but I need to change it for a specific sheet, (For eg: In sheet 1- arro size must be in 3units and in sheet 2 arrow size must be in 6units. Because of the model scale.) Is it it possible to change? or is it a standard for the process? If any one know that process like config or settings please lemme know.
Thanks in Advance
Aug 8, 2024 11:00 AM UTC
requested functionality is not implemented. Instead of creation single drawing with multiple sheets you have to create multiple drawings with one sheet.
Emeritus
Aug 8, 2024 10:33 AM UTC
Hi Mani_designer,
Thank you for your question.
Vivek N
Community Moderation Team.
Aug 10, 2024 9:52 AM UTC
Thanks for the reply Mr,Namboodheri. As you said I'll make an additional details.
Thank you
Aug 10, 2024 9:50 AM UTC
THanks for your reply. Is it the only option that I could do or any other options like scripting process are there?
Aug 12, 2024 7:10 AM UTC
1.] detail options are valid for all drawing sheets
2.] scripting process (probably you use Autocad LISP) is not available in Creo
