Aug 3, 2015 7:15 AM UTC
compatible of CRO 2.0 with Wildfire 4.0
Is there any way to open a CRO 2.0 created 3D Model with Wildfire 4.0?
    Aug 7, 2015 2:01 PM UTC
    Alexander,
    you can use GRANITE-based Cross-Release Interoperability for PTC Creo, see http://support.ptc.com/products/granite/gcri/index.htm. Unfortunatelly you will not see all model features in WF4. You will get dumb geometry.
    Also I am not sure if this functionality works with Student/Academic licenses.
    Martin Hanak
    Alexander,
    Martin Hanak
    Aug 25, 2015 5:59 PM UTC
    No, Creo is never backwards compatible. Depending on the need, you can always create a STEP file of the part or assembly and import it into the older version. This will of course drop all the features, dimensions and constraints of your source geometry.
