Nov 3, 2010 9:55 PM UTC
Could Windows 7 be the Culprit? (Install issues)
I'm having issues installing the latest Student Edition of Creo Elements/PRO 5.0. At the beginning of this semester (almost two months ago), I was able to seccessfully install and use the Wildfire Student Edition on my desktop PC at home. It runs very well. However, I picked up a new laptop a couple weeks ago, and I'd really like to do work in places other than my room, but my installation gets to 1 or 2 percent and it freezes with the status of "copying files." I've tried leaving it alone for a couple hours to see if it improves, but it doesn't. The second green bar is full (100% download supposedly), but when the install freezes, I have to manually close the program from the Task Manager. I've tried multiple configurations and have uninstalled/installed many times and have even created a second account in an attempt to troubleshoot, but I'm having no luck.
I'm running Windows 7 on the laptop (64-bit). The PC with the working copy is running Windows XP. Has anyone else had a similar experience? I have the license '.dat' file on the laptop, which was generated during the install attempts. If I try to get a new license, it tells me I'm maxed out with both accounts now. I really hope someone can give me other suggestions.
-Eric Scheer
Student at STCC
    Nov 3, 2010 10:00 PM UTC
    If you have the option to download the full DVD for install, do so. I have heard of issues with trying to do the web install.
    Hope that helps,
    Tim
    Nov 4, 2010 10:33 PM UTC
    The full download worked splendidly. I had started downloading it previously, but had to keep pausing it while I jumped between networks. Your solution is much appreciated.
    Eric
    Mar 12, 2011 4:43 AM UTC
    I am experiencing the exact same challenge as Eric, but am not given the option for a full DVD download. Any ideas what else might help me get Creo installed? I am running W7 in 64bit mode, trying to install the right version and have plenty of memory. The issue is that it stops at 1% or 2% like it did for Eric.
    Thanks.
    Kurt
    Mar 15, 2011 12:08 AM UTC
    Kurt,
    Which edition of Creo are you attempting to install? Since this is posted to the University Program forum I assume a University edition.
    The DVD for Schools Edition (for college or university students) can be downloaded here: www.ptc.com/go/license4schools-uni
    Adam
    Mar 15, 2011 12:34 AM UTC
    Thanks Adam,
    I have accessed the PTC site for this, entered my computer's MAC address and am waiting for an email that contains information I need to download the DVD. At least that is what I assume I am waiting for.
    Will this be different than what I have downloaded before? What I downloaded before was one compressed file that had Creo for 32bit and Creo for 64bit, with a small text file. That file appeared to download fine, but upon installation it would hang up at 1% or 2% during the "copying files." Where there missing files in that .zip download? I look forward to trying it again with the information I am waiting for.
    I will let you know what happens and thanks for the help.
    Kurt
