Creo 1.0 license utility problem
Hi everybody !
It's now two days that i search all the way to find a solution to install Creo 1.0. I want to install the school version i'm following the process that the help gives you. The trouble is that when i'm downloading Creo 1.0 License utility i can't make it run my computer show me two possibility :
The installation is made correctly (if i press it nothings happen)
Make a reinstallation (if i press it well nothing happens too !)
I'm getting a bit crazy because then i can't create my PTC account and then i can't use it,
I need it for my school project so if you can give me some advice i would be grateful !
Have a good day and see you soon !
Magdaléna
    Answer
    October 25, 2013
    This is most likely due to your virus or firewall protection.
    Instead, use the instructions in this document to install the Student edition of Creo 1.0: http://apps.ptc.com/schools/references/install_creo1_student.pdf
    For the fastest response to your issue, your best bet is to fill out the PTC Academic Support Form.
    Answer
    October 25, 2013
    Hi there
    one simple question. I filled out the document and click submit a few times, but in every case the page generates itself back to the empty mask.
    Is there a kind of information given, that the submitting was clear, or is it quiet normal, that no further information is given?
    Thx a lot
