May 6, 2026 2:42 PM UTC
Creo 12 Academic: License file empty (0 KB) despite "Success" status - HostID mismatch/writing issue
Hello, I am a student trying to install Creo 12 Academic Version. I am encountering a persistent issue during the licensing step: The Issue: After entering my Product Code (BK...), the installer displays a green "Success" status. However, I cannot proceed, and the generated license file in C:\ProgramData\PTC\Licensing is empty (0 KB). Technical Details: Version: Creo 12.0 Host ID: [Available upon request for PTC Staff] Product Code: BK120908EDUNIVERSITYED Troubleshooting already done: Ran the installer as Administrator. Disabled Windows Firewall and Antivirus. Verified that the Host ID matches my active network card (other adapters were disabled). Cleared the Licensing folder and attempted a re-install. Verified that the "Controlled Folder Access" in Windows is disabled. Despite the server validation (Success), no data is written into the .dat file. Could you please provide a valid license file or reset the activation for my Host ID? Thank you for your help
May 6, 2026 2:53 PM UTC
To provide more context for the support staff, here is my current ipconfig /all output.
Configuration IP de Windows
   Nom de l'h“te . . . . . . . . . . : DESKTOP-STPQIJB
   Suffixe DNS principal . . . . . . :
   Type de noeud. . . . . . . . . .  : Hybride
   Routage IP activ‚ . . . . . . . . : Non
   Proxy WINS activ‚ . . . . . . . . : Non
Carte Ethernet Ethernet :
   Suffixe DNS propre … la connexion. . . :
   Description. . . . . . . . . . . . . . : Realtek PCIe GbE Family Controller
   Adresse physique . . . . . . . . . . . : 2C-F0-5D-D3-94-E8
   DHCP activ‚. . . . . . . . . . . . . . : Oui
   Configuration automatique activ‚e. . . : Oui
   Adresse IPv4. . . . . . . . . . . . . .: 192.168.1.97(pr‚f‚r‚)
   Masque de sous-r‚seau. . . .ÿ. . . . . : 255.255.255.0
   Bail obtenu. . . . . . . . .ÿ. . . . . : mercredi 6 mai 2026 16:23:57
   Bail expirant. . . . . . . . .ÿ. . . . : jeudi 7 mai 2026 04:23:57
   Passerelle par d‚faut. . . .ÿ. . . . . : 192.168.1.254
   Serveur DHCP . . . . . . . . . . . . . : 192.168.1.254
   Serveurs DNS. . .  . . . . . . . . . . : 192.168.1.254
   NetBIOS sur Tcpip. . . . . . . . . . . : Activ‚
As you can see, I have already:
  1. Disabled IPv6.
  2. Disabled all other secondary or virtual network adapters.
  3. Confirmed that the Host ID 2C-F0-5D-D3-94-E8 is the only one active.
Despite this clean setup, the license file generated by the installer remains at 0 KB. I hope this helps in generating a manual license file for me.
Thank you!
May 6, 2026 3:50 PM UTC
same issue
May 6, 2026 8:47 PM UTC
Also have this issue
3-Newcomer
May 7, 2026 10:09 AM UTC
I have the same issue. After installing thelicense the file is empty
6-Contributor
May 8, 2026 4:39 AM UTC
same issue
May 18, 2026 11:47 AM UTC
Update: 10 days later, I am now getting the error "You have reached the maximum amount of requests for your product type".
Because the installer previously generated empty 0 KB files while displaying "Success", the system probably flagged my multiple attempts as multiple activations.
Could a PTC administrator please reset the activation count for my account/Host ID (2C-F0-5D-D3-94-E8) or generate the text for the .dat file manually? I am completely blocked for my studies. Thank you.
