Creo 2.0 Issue with Assemblies
Hi, I'm new here. Maybe this issue has a common, easy answer.
Creo will not open any assemblies, or create any new ones. It doesn't explain why, either. You can click on assembly files to open them, or create new ones, name them, and click 'create' or whatever, and then nothing happens.
The issue is with Creo Direct 2.0 Has anyone run into this before?
Thanks!
Jack
    Here's why it is. Student Licenses in Direct can't use assemblies. Oops.
    I am not having this kinda problem, but seems like activate issue. Can u click on view> activate> then try? or it is happening from scratch?
    It's basically happening from scratch. Just now, I tried clicking 'activate,' and then opening an assembly, and then clicking it again right after I 'opened' it. Nada. Is this characteristic of an install issue? Do people usually get those?
    so after activating it, its working for once?
