Creo 2.0 student edition error message
Hi
In my Uni we use Creo 2.0 as the main CAD software and I have homework to do with it.
I successfully installed the sw on my computer, however when when I tried to run it, I got the error message shown below.
I also tried a couple times to run as administrator, install as administrator, dowload quality agent, etc, but not get any right results.
When quality agent is not installed, it shows a different error message with a question if I want to register quality agent. Both Yes and No answer leads to the shutdowb of Creo.
Could anybody please help me? Thank you!
Error message:
    ChrisCarrAnswer
    Hi Laszlo,
    This is a know issue some people are having with Creo 2.0. It occurs in the later build codes and we're working on a solution to the problem. In the meantime, your best bet is to download Creo 2.0 M130 from the link below and install it. That's the latest version that has been verified to be error-free.
    http://www.ptc.com/appserver/auth/it/esd/academicFree.jsp
    Let me know if that helps.
    Chris
    ChrisCarr1-VisitorAnswer
    Hi Laszlo,
    Chris
